Xerox nuvera error
  • azehnali
    • Nov 2009
    • 677
    Xerox nuvera error
    does anyone know what C16-355 on a nuvera means ?
  • Milo Wilson
    • 508
    Re: Xerox nuvera error
    Communication problem from Sys board through the SCSI cable to motherboard
    • azehnali
      • Nov 2009
      • 677
      could it be corrupted software or something else?
      • Milo Wilson
        • 508
        check the cable connections. Could be a network cable is plugged into the wrong port or bad scsi cable
        • azehnali
          • Nov 2009
          • 677
          how about PEM 03 3970?
          • adriansto
            • 2395
            Battery located on Software/NVM module on Main Controller Pwb.
            You need to restore nvm or replace Sw/NVM module and restore nvm.
            You dont have service manual ?
            • Milo Wilson
              • 508
              Might just have to replace the nvm battery then do the configuration setup
              • azehnali
                • Nov 2009
                • 677
                I dont have the manual
                is it complicated ?
                • azehnali
                  • Nov 2009
                  • 677
                  also do you know how to restore nvm on a docucolor 260?
                  • adriansto
                    • 2395
                    Nuvera is only a little production machine. It is only like half part of Hodaka ! I think is very but very simple to do service without manual.
                    What nvm for DC260 ? Probably the region mvm ?
                    • Milo Wilson
                      • 508
                      Go into diagnostics and do an NVM init.
                      • azehnali
                        • Nov 2009
                        • 677
                        on the 260 I can not connect to it with diagnostic navigator only through the download navigator and it shows nvm errors and the machine does not boot up
                        • azehnali
                          • Nov 2009
                          • 677
                          how do you get into diagnostic mode on the nuvera?
                          • Milo Wilson
                            • 508
                            On the machine itself. Like logging into a docuSp server. If the license string is not active then you have to get a new diagnostic license string before going into Diagnostics.
                            • piotr_krak
                              hello
                              A have one question for nuvera 120. Now i have code PEM-03-3970. I don,t have manual for this machine. You write that it should restore or replace and restore NVM.
                              So i ask. How should I must do it this procedure correctly?
