Tested My new M24. Strange colorthing happened..
  • Stroker
    • 36
    First and second and third look as the picture and then the rest look normal. Same when trying after a o hour and then after the first the rest of the nine was perfect.
    It was a heavy transportation with a lot of bending, shaking and so just to get it into my basement, so could it be that the "tractor trail" in top and bottom is toner that has been shaking around inside the machine?
  • Milo Wilson
    • 508
    Re: Tested My new M24. Strange colorthing happened..
    Needs a new IBT cleaner blade and/or cleaner blade assy
    • Stroker
      • 36
      I just cleaned and blow it with the compressor and now it has made 1200 copies perfect printing Thanks for advice. There was a piece of paper that fell out who it seems has been making the problem ..Could be the paper that should sit there who has loosen or maybe a paper you shall take away ???? when installing a new one. The plastic didn't look worn at all..
