Color problem whith DC 250
  • ferranmll
    • Feb 2011
    • 21
    Hello I've a Docucolor 250 that no print a little area in yellow. I print test pattern 12(see att. files). I change the drum, change de IBT belt assembly for 1rst BTR Bias damage, the result is the same in the both IBT. I change de developer in the developer housing. Can you help me?
    Thanks.DC_250655.pdfDC_250656.pdf
  • bojans
    • 1313
    Re: Color problem whith DC 250
    First i would clean laser.
    • xcopytech
      • Aug 2006
      • 1794
      yes, clean yellow and cyan laser.
      • ferranmll
        • Feb 2011
        • 21
        Sorry, I do this first.
        • bojans
          • 1313
          Did you try to swap laser units?
          • ferranmll
            • Feb 2011
            • 21
            I didn't. I will try tomorrow. Thanks.
            • xcopytech
              • Aug 2006
              • 1794
              you must remove miror for yellow and cyan color in laser assembly to clean it.
              • JustManuals
                • Jan 2006
                • 9838
                Paul@justmanuals.com
