workcentre 7335 error code 009-349
  • WCSSTORE
    • Dec 2011
    • 19
    [Error Code] workcentre 7335 error code 009-349
    Hello I got a xerox workcentre 7335 with a error code 009-349. It started when 1 of my workers took an air hose and blew the inside of the machine out (yes I know it was a bad idea). I know it has to do with the 1 btr, so we changed it out (figuring a quick fix) but we still get the code. Does anybody know if I have to have a PWS system to reset this code or can it be done on the copiers control panel?
    I know how to get to the maintenance back door part
    Hold down 0 (zero) for 5 seconds and press start (green) button
    enter 6789, confirm
    press log in/log out button or the key button
    press systems settings, common settings, maintenance, NVM read/ write
    But don't know the number to type in and set to zero.
    Thanks in advance
  • tech9
    • 216
    Re: workcentre 7335 error code 009-349
    most probably blown toner dust into 1st btr retract sensor on the IBT ass. Clean the sensor.
    • WCSSTORE
      • Dec 2011
      • 19
      Hello and thank you for your response
      We have replaced the IBT assembly (swapped from a parts machine), but we still get the code.
      Is there a way to reset this code through the NVM chain link?
      Thanks Again
      • johnner66
        • Mar 2009
        • 265
        have you try change the mdd pwb good luck........once of the fuse blow ... so the retact motor no function ...
        • WCSSTORE
          • Dec 2011
          • 19
          Thank you all for your help. I ended up taking the machine to a repair place and was told a board failed and that the price was to much to repair. So we bought another xerox 7335 and kept the old one for parts.
          Thank again
          Dave
          • johnner66
            • Mar 2009
            • 265
            try that take out the if ddm pwb board and check there is a fuse blow ...replace the fuse will cost you few cents ....
            • xeroxsharp
              • Nov 2008
              • 270
              Thanks Again
              NVM 741-056 to 0
