I have a docucolor 252 with a fiery rip. Whe I go to command workstation to log into the machine I keep getting an error and the conection is lost. I log in to the I/P address and have the same issues, will not stay logged in long enough to do anything. I replaces the cat 5 wire and even the network hub. The maching has no error code and can copy from the glass just fine. Has anyone had this sort of issue?
Fiery connection problem
Re: Fiery connection problem
I have a docucolor 252 with a fiery rip. Whe I go to command workstation to log into the machine I keep getting an error and the conection is lost. I log in to the I/P address and have the same issues, will not stay logged in long enough to do anything. I replaces the cat 5 wire and even the network hub. The maching has no error code and can copy from the glass just fine. Has anyone had this sort of issue?Color is not 4 times harder... it's 65,000 times harder.They call it "TECH MODE" for a reason. I have manual's and firmware for ya, course... you are going to have to earn it.
thank you! any idea how I can get the software to put on the new hard drive?Comment
Best thing to do is pay a tech, even if you get the software and manage to install it you won't have the patches and security updates that NEED to be done. Want your Fiery hacked and hosting porn sites? Laugh if you will, I've seen it happen.Color is not 4 times harder... it's 65,000 times harder.They call it "TECH MODE" for a reason. I have manual's and firmware for ya, course... you are going to have to earn it.
I am a Tech, just don't have xerox fiery software. I work on KM most of the time, just have this xerox I need to get back up and running. Thanks for your help!Comment
after the boot it stops on 00. I did find the install disks for the software and ordered the hard driveComment
Good luck.Color is not 4 times harder... it's 65,000 times harder.They call it "TECH MODE" for a reason. I have manual's and firmware for ya, course... you are going to have to earn it.
