xerox 510 intermittent Black line
+ More Options
Posts
  • mdm
    • Jun 2009
    • 132
    I have been having issues with a xerox 510 with a 3millimeter thick black line that comes from the machine.
    I would run electrostatics and that would complete with no errors. The line does print on every print/copy
    but on every other print/copy.
    Thanking you in advance for your help.
    mdm
  • technogeek2009
    • Mar 2011
    • 167
    Re: xerox 510 intermittent Black line
    I am guessing the line runs in the process direction. If it runs across the print as it comes out, that would be a completely different matter. Lines as you describe generally are caused by a dirty scorotron. When cleaning the pin array and shield, be certain not to use a towel or anything that may transfer lint to these components. I prefer to use a brush, then follow up by wiping the parts down with my fingers. A close visual inspection afterwards insures clean parts.
    • mdm
      • Jun 2009
      • 132
      You are right the lines are in the process direction. We have replaced the transfer socrotron but I will do
      like you said and take down clean and inspect. I will also look at the charge as well.
      Thanks.
      mdm
      • technogeek2009
        • Mar 2011
        • 167
        Just for future reference, the transfer would only cause light streaks in the print, not black lines.
        • mdm
          • Jun 2009
          • 132
          Thanks technogeek 2009,
          you were right on, I replace screen and clean charge scorotron and copy/prints
          are excellent.
          Thanks again.
          mdm
          • technogeek2009
            • Mar 2011
            • 167
            You are very welcome if I may help again, drop me a note cbyrne@goevergreen.net I can also help you with parts.
