xerox 8830 E7.01 error
  • javier4065
    • Feb 2007
    • 251
    Hello what Should I do to solve this problem ? and what should I check ? thanks.
  • adriansto
    • 2387
    Re: xerox 8830 E7.01 error
    There are a service cd who help you to solve the problem.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • walidcharifi
        • Feb 2011
        • 379
        hi
        i have z service repaire file pdf send me your mail
        walidcharifi@yahoo.com
        • technogeek2009
          • Mar 2011
          • 167
          The E-701 code indicates that the printer and controller are not communicating. Typically, this is due to a problem with the controller. There is no simple solution to this problem as there are many different causes for controller problems. The others are correct in advising you to get a service manual. However, you will need the AccXES Legacy controller manual. The controller is not covered in the 8830 printer manual.
          If you are not a technician, you may want to find one locally. Some of the troubleshooting for controller failures requires a knowledge of both computers and electronics.
          • javier4065
            • Feb 2007
            • 251
            thanks friend but I'm technician and I need information to solve this problem.
            • technogeek2009
              • Mar 2011
              • 167
              Were you able to acquire the controller manual? As I mentioned before, troubleshooting this problem is too involved for simple suggestions on this forum. Check to be sure all voltages are coming from the power supply. What version controller do you have? This can be determined by looking at the serial number plate on the controller. The attached controllers begin with F5Y, N5T, CNG, or EV4. The stand alone controllers are HFT or PUN. Each different controller has a slightly different set of indicators which help diagnose the problem with the controller. This is where having the manual will help dramatically.
