Workcentre 5675 Controller Help Needed
  • mrfuser
    • 1617
    I have a couple of 5675 units that I picked up for a client and later found out someone had removed the HDD out of the print controllers, thus they do not function. I have the software tool for the 5632-5687 but if I can't get controller up I can't use the tool. Any idea how to install a new HDD in the controller and add needed firmware to make it work?
    Thank you in advance!
    Kelly
  • seansbar
    • Dec 2010
    • 198
    Re: Workcentre 5675 Controller Help Needed
    Any HDD will work, as long as it fits. But, you will need a PWS to ALTboot (install the software from scratch)
    • tech9
      • 216
      you need the 5675 pws tools and software on you pws you can try the 275 tools as i have altbooted a 275 with 5675 tools.
