mcu nvm in a wc7655
  • funcom
    • Aug 2009
    • 28
    mcu nvm in a wc7655
    i replace the mcu nvm in a wc7655 and i have to serialize.
    how can i do this?
    Somebody help me?
  • maich4s
    • Mar 2009
    • 86
    Re: mcu nvm in a wc7655
    hello,if u have a pws kindly go through all the nvms of the dc250 and im sure u will get something close
    • funcom
      • Aug 2009
      • 28
      But when connect the usb cable in wc7655 the laptop needs the driver dc-551
      can explain?
      • maich4s
        • Mar 2009
        • 86
        does your pws have diagnostics tool for wc7655?
        • funcom
          • Aug 2009
          • 28
          no i only have to dc-250. can you help.
          • maich4s
            • Mar 2009
            • 86
            get someone with pws that has diagnostics software for the workcentre 76xx family.are u in africa?
            • adriansto
              • 2383
              What version of firmware do you have on machine - 40.032 or 40.033 ?
              • maich4s
                • Mar 2009
                • 86
                i have personally never done it on a workcentre76xx family,i have only performed this on dc12 and you need a pws(its a MUST)in dc250 you will
                Enter UI Diagnostic mode (see Accessing UI Diagnostics).
                Select Adjustment/Others.
                Select Machine ID/Billing Data Settings.
                Select a PWB with the correct data.
                Select Start.
                Enter the correct serial number in the Serial Number screen and then select Confirm.
                i hope this helps,and gives u ideas on where to look at,note that Diagnostic for dc250 and workcentre are very diffrent,so u have to get that series Diagnostic software.
                • funcom
                  • Aug 2009
                  • 28
                  Select Start.
                  You have the diagnostic to 7655?
                  • maich4s
                    • Mar 2009
                    • 86
                    i have a fully loaded pws,if you are in africa then we can see how to go about it,if not then kindly send me mail in my email(maich4s@yahoo.com)then i can give you contacts where to buy the softwares and new updated pws(most preffered)
                    • funcom
                      • Aug 2009
                      • 28
                      Thanks, but i'm portugal.
                      • maich4s
                        • Mar 2009
                        • 86
                        ok mail me if you new the softwares and pws
                        • moniinfo
                          • Dec 2012
                          • 3
                          I have the same problem. Do I need a special usb cable for PWS?
