Xerox wc5775 Ready To Copy, Please wait adjusting fuser module (R3) Temperature
  • mdm
    • Jun 2009
    • 132
    Hi, hoping that someone seen this problem before.
    Working on a Xerox WC 5775 There are three sets of faults: 10320, 10380. I tried
    another working fuser and the same problem. Any help appreciated.
    Thanks.
    mdm
  • xeroxsharp
    • Nov 2008
    • 270
    Re: Xerox wc5775 Ready To Copy, Please wait adjusting fuser module (R3) Temperature
    Bad LVPS or NVM corrupsion.
    • adriansto
      • 2387
      Before check LVPS or do NVM init you must take a look at the fuser connector located in machine especially at thermistors contacts.
      • mdm
        • Jun 2009
        • 132
        Thanks Xeroxsharp and Adriansto,
        I am ordering a LVPS and IOT PWB to take care of problem, I will keep you all inform.
        Adriansto, could give me a little more info on what to look out for on the fuser contacts.
        Thanks.
        • adriansto
          • 2387
          10-380 error code mean reading differece between the two thermistors from fuser assy.
          May be a bent contact(s) in fuser conector located in machine. You exclude the contacts connector on fuser assy because already tried two fusers assy and get same error.
          • mdm
            • Jun 2009
            • 132
            Thanks Adriansto, I will check fuser connector.
            • kinga sithup
              Were you able to solve this problem? Could you please help me I have same problem.
