pro 65 09.370 error wont clear
  • mrfuser
    • 1617
    [Error Code] pro 65 09.370 error wont clear
    Can't clear the 09.370 code.
    Any help?
  • Enzo
    • Jul 2009
    • 413
    Re: pro 65 09.370 error wont clear
    Fault Code, 09-370, indicates that the Transfer HVPS fuse is open or that the power supply is on in standby. The Transfer Fault Monitor signal is High when the Transfer Enable should be Low.
    • mrfuser
      • 1617
      Thank you. This I know. There is no fuse on that board, but it is not putting out proper voltage.
      QUOTE=Enzo;285005]Fault Code, 09-370, indicates that the Transfer HVPS fuse is open or that the power supply is on in standby. The Transfer Fault Monitor signal is High when the Transfer Enable should be Low.[/QUOTE]
