Xerox dc 250 misregistration and high magenta on all prints
  • vibin
    • Sep 2011
    • 38
    HI all,
    i had a problem with my Dc 250 from last wednesday. It started by showing high magenta density on prints.
    We cleaned the ros, tried to switch the drums, changed the IBT belt, Developer unit with out any success.
    On trying to tone down, the magenta values donot change much but keeps jumping up each time you try to tone.
    The tech advised us to clean the MOB ADC ASSEMBLY.Even after doing so we didnt experience any luck.
    After trying to tone down. i lot the registration.
    I tried to intialise NVm, run regicon.No luck at all.
    Please help me out. i have attached frew pics.
    Any asistance will b ehighly appreciated.
  • livewire
    • Sep 2011
    • 608
    Re: Xerox dc 250 misregistration and high magenta on all prints
    Do you have Fault Codes starting with 089-XXX? What are the errors from wednesday to today?
    • vibin
      • Sep 2011
      • 38
      Nop, I havent got any errors as yet....!!
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • livewire
          • Sep 2011
          • 608
          Since there are no errors in Error History Report, to see what version of software. Have you installed the Updates or Patches on Controler?
          • JRCS
            • 43
            Did you check that the ROS is on correctly?
            • azehnali
              • Nov 2009
              • 679
              looks like something is wrong with black developer housing
              do you have a smaple of a print
              • Scarecrow
                • Oct 2010
                • 234
                Are there factory settings for the regicon adjustment buried in the machine somewhere?Use them to start the registration adjustment -- worked for me on a 73 series I couldn't adjust. I'm sure you've checked the magenta dev bias, and made sure you don't have a partial short to ground for the charge, and you do have a short to ground from the inside of the drum, and the toner is oem, and dev housing is good, and other stuff I can't remember right now, like is there enough developer in the housing (severely overtoned and there is not enough dev to clean the background area of the drum)?
                Glenn
                • vibin
                  • Sep 2011
                  • 38
                  Managed to sort out the registration issue.
                  i reloaded the nvm using the pws
                  just r an the registration measurement cycle like 10 times and it just swung back into action.
                  But the problem of high magnets concentration still continues.
                  • vibin
                    • Sep 2011
                    • 38
                    Still have the heavy magenta output on all prints.
                    • Eagle
                      • Mar 2010
                      • 49
                      when u changed the Mag Developer unit did u input the numbers from the bottom of the Developer unit in to the machine??? So it gets the right Values???
