wc pro 35 super dark copies, print is fine
  • mrfuser
    • 1616
    We swapped the entire scanner assembly and we still get super dark copies, but report test prints are fine. Once in a while we get a clean copy.
    Any ideas?
    Thanks all
    Kelly
  • ZeusGT
    • 271
    Re: wc pro 35 super dark copies, print is fine
    Have you replaced the logic that controls the CCD of the scanner? I would try that. I had a Xerox that did the exact same thing and it ended up being the logic board.
    CompTia A+ Certified
    CompTia Net+ Certified
    CompTia Server+ Certified
    CompTia Project+ Certified
    OP Scanshare Certified
    • WIWA
      • Mar 2009
      • 97
      Well if prints are fine this is good , so concentrate on optics/scanner verify optics cavity if its clean and wipe carefully the document glass . Also check for the lamp illumination and white reference patch.
      Hope this helps,
      Wiwa 72
      Gonzos build V. 1.0
