Xerox 3545 alt boot
  • azehnali
    • Nov 2009
    • 679
    Xerox 3545 alt boot
    has anyone reloaded software on hard drive via altboot method?
  • xcopytech
    • Aug 2006
    • 1783
    Re: Xerox 3545 alt boot
    what kind of problem you have?
    • azehnali
      • Nov 2009
      • 679
      when it goes to download the ekp file ir fails to comunicate
      • xcopytech
        • Aug 2006
        • 1783
        which ip address you have on laptop?
        • azehnali
          • Nov 2009
          • 679
          100.100.100.102 I think
          what should I have?
          • adriansto
            • 2372
            Read help file from altboot or general procedure from edoc and you'll know the ip address
            • xcopytech
              • Aug 2006
              • 1783
              ip address 192.168.0.10
              subnet 255.255.255.0
              • tech9
                • 216
                What altboot tool are you using ?
                And PWS image ?
                On the newer image you have to use altboot 6.1
                and send the EBC file via the network cable.
                • azehnali
                  • Nov 2009
                  • 679
                  Using the one with white screen
                  • xcopytech
                    • Aug 2006
                    • 1783
                    Try to set up IP address as I wrote before.
                    If that do not help send me pm.
                    • azehnali
                      • Nov 2009
                      • 679
                      did the ip
                      the message I get is
                      maximum retransmits exceeded
                      check communications line
                      reset machine and /or pws application if necessary
                      i am using a cross over cable and serial cable with null connector
                      • adriansto
                        • 2372
                        Check again your crossover cable or try with another.
                        Also take a look at memory simm located in net controller.
                        May be ekpxxxxxx.os file you have is corrupt. What is the version of the file and what is its size ?
                        • azehnali
                          • Nov 2009
                          • 679
                          The cross over cable is good
                          i loaded software on a 7675 two weeks ago
                          i have tried 3 different software versions and all do the same
                          do you mean the RAM ?
                          • Tinochka
                            • Jul 2012
                            • 127
                            A few days ago I used to have the same problem. After I turned off the firewall and allow all traffic everything goes ok!
                            • seansbar
                              • Dec 2010
                              • 198
                              2x corrupt file
                              First time I ALTBOOT, tried 3x. Called X. They said download software again and use altboot tool in download. It worked!
