xerox dc242 problem printing
  • costou
    • Sep 2009
    • 44
    Hello,
    I have a DC242 with fiery controller, when I print something from a computer or sending directly something from the fiery, i have a problem like you can see in the 3 photos.
    I intempt to send something from pdf, photoshop, word, always the same thing.
    In copy mode, no problem, all is OK, so i think a problem from cable or i don't know what.
    If somebody had the same things.....
    Thank you.
  • fogra27
    • Mar 2011
    • 29
    Re: xerox dc242 problem printing
    1) flip over and reseat the thick cable from fiery to machine
    2) reinstall fiery SW
    3) reset nvm in the machine...
    cheers...
    • costou
      • Sep 2009
      • 44
      thanks for your answer.
      1) cable seems to be ok, i flip it, and the same
      3) i reset all the NVM, and it's the same
      2)i'm searching the soft to reinstall it, when i find it, i will say to you what happen.
      thanks
      • azehnali
        • Nov 2009
        • 679
        try switching the cable from scanner to copier with the fiery cable
        they are the same
        if not reload software
        • adriansto
          • 2388
          thanks
          Did you try to reseat boards and memory simm from inside Fiery ?
          Also take a look at the heatsink for processor.
          • 123cbboy123
            Are you sure the copy is fine.it seems like ibt cleaner faulty
            Chech internal pages from diagnostic,are fine?
