Looking for XEROX 5632/5638 5645/5655 and 5665/75/87 Firmware
  • walidcharifi
    • Feb 2011
    • 379
    #31
    Walidtirage#yahoo.com
    • Enzo
      • Jul 2009
      • 413
      #32
      Re: Looking for XEROX 5632/5638 5645/5655 and 5665/75/87 Firmware
      Originally posted by xcopytech
      What version of altboot you have?
      Do you have null modem cable?
      Connect null modem cable to serial port on controller and on PC.
      Also need cross over network cable.
      yes, I have all the serial cables, including null modem.
      I have the ALTBOOT version 20.3 - WC5632-5687F
      I would like to know how to proceed to reload. how to set up the network settings with the inserted Ethernet cable.
      • adriansto
        • 2392
        #33
        Where is the null modem ?
        Are you sure the orange device is really a null modem ?
        • Enzo
          • Jul 2009
          • 413
          #34
          Yes my friend. I am sure because I use the same cable to reload on xerox 440st and it works fine.
          • xcopytech
            • Aug 2006
            • 1794
            #35
            Set pc ip address to 192.168.0.10
            Connect null modem and crossover with controller.
            Start altboot.
            Power on machine
            After a few seconds you should get some text on altboot screen.
            Then press any key to interupt boot.
            • Enzo
              • Jul 2009
              • 413
              #36
              Here is the error! Unfortunately I can not fix it! I followed all your instructions
              • xcopytech
                • Aug 2006
                • 1794
                #37
                If you have another machine it will be good to try altboot on it.
                I think that your altboot sofware is corrupted.
                • Enzo
                  • Jul 2009
                  • 413
                  #38
                  I think so too! also on another machine it gives the error. I need to reload the software!
                  • Btknetworks
                    #39
                    Guys am looking for Xerox 5655 firmware that I can load using a usb flash drive altboot. May you also give me instructions on how to load please
                    • Enzo
                      • Jul 2009
                      • 413
                      #40
                      Hello friends. I finally managed to start the altboot for the xerox 5645 with mbc controller. Just started the program, it asks me for the password (as from photo). what password should I enter?
                      • InterfaceP
                        • Jun 2013
                        • 488
                        #41
                        [ATTACH=CONFIG]36624[/ATTACH]
                        try "1111" or "11111"
                        • Enzo
                          • Jul 2009
                          • 413
                          #42
                          No friend, unfortunately it does not work. I've also tried other "standard" codes, but nothing!
                          • adriansto
                            • 2392
                            #43
                            There isnt any passwd for altboot.
                            The bios controller dont see the hdd.
                            Harddisk is missing, or it is bad, or hdd cable or connection bad, or ...
                            • Enzo
                              • Jul 2009
                              • 413
                              #44
                              Ok! I've also tried with another controller and the situation is the same! Do you think it is better to format the hard disk from the PC and then try again with the altboot?
                              • osos
                                • Mar 2017
                                • 3
                                #45
                                hello,
                                I need a diagnostic tools and edocs for Xerox WC 56xx compatible with old version PWS 9.2 , can anyone help me
