WC PRO 255 DOC.FEED HELP
  • jper34
    • Sep 2011
    • 225
    Hi folks,
    Im working on this WC Pro 255,thats telling me to lift feeder and lower flap to remove paper.Of course,theres no papaer,I did however,remove a staple that was stuck in there,still jam coe 05-538, and 05-522. I cleaned the photo-interrupter and made sure sensor arm springs back o.k. can anyone help me w/ part number for this sensor,and has anyone seen this sensor go bad?
    thanks in advance
    Jaime
    Independent Copier
  • adriansto
    • 2375
    Re: WC PRO 255 DOC.FEED HELP
    Did you use the correct feeder roller cru for this dadf ?
    • jper34
      • Sep 2011
      • 225
      Originally posted by adriansto
      [ATTACH]15914[/ATTACH]
      I did replace the pick-up separation assem., is that what mean by cru?
      and it that was maybe 2 weeks past now..? what am I missing?
      • adriansto
        • 2375
        Yes pick-up separation assy = cru. There are cru for wc535, wcp55 machine and another cru for wcp2xx series machine. What code is marked on your cru ?
        • jper34
          • Sep 2011
          • 225
          i used part# 113686
          workcenter pro 255 is the model
          • jper34
            • Sep 2011
            • 225
            113r686
            • adriansto
              • 2375
              113r686
              Yes this is the partnumber.
              The sensor from attached pdf file is you looking for ?
              • xeroxsharp
                • Nov 2008
                • 270
                Hi folks,
                thanks in advance
                Jaime
                Independent Copier
                item 11,12
                Item Part No. Description
                1 - Hinge (P/O PL 5.20 Item 16)
                2 - Bushing (P/O PL 5.20 Item 16)
                3 022E25061 CVT/Takeaway idler
                4 806E19680 Shaft
                5 - Torsion spring (green) (P/O PL 5.20 Item 17)
                6 - Base (P/O PL 5.20 Item 17)
                7 - Spring (P/O PL 5.20 Item 17)
                8 - Torsion spring (silver) (P/O PL 5.20 Item 17)
                9 029E37810 Latch pin
                10 - Spring plate (P/O PL 5.20 Item 17)
                11 130K73960 Takeaway sensor (Q05-335) ( REP 5.8)
                12 130K73970 CVT Sensor (Q05-350) ( REP 5.8)
                13 - Sensor support (P/O PL 5.20 Item 17)
                14 - Shaft securing bracket (P/O PL 5.20 Item 17)
                15 - Top cover (P/O PL 5.20 Item 16)
                16 802K93770 Top cover assembly (RoHS) (W/ TAG D-050)
                802K62060 (Non-RoHS) (W/O TAG D-050) ( REP 5.1)
                17 055K36650 Top access cover assembly (RoHS) (W/ TAG D-050)
                055K33563 (Non-RoHS) (
