WCP 65 error communicating to scanner
  • Enzo
    • Jul 2009
    • 413
    Hello friends. I have a notebook with Windows XP sp2. Yesterday I have formatted and now I can not to make the scans from the machine into my computer! Can anyone help me configure my computer? thanks
  • adriansto
    • 2388
    Re: WCP 65 error communicating to scanner
    Disable firewall from WinXP
    Also have a user name and password for scan user.
    Read the help Q. & A. on www.xerox.com
    • Enzo
      • Jul 2009
      • 413
      hello friend. The firewall is disabled. I put all the necessary settings in the machine and via the web, but the scan does not work!
      • adriansto
        • 2388
        Which method you choose - scan to ftp or scan to smb, scan to home ?
        • Enzo
          • Jul 2009
          • 413
          Then. I have the machine connected to the notebook. Yesterday I formatted the computer and I lost all the settings of my computer but not the machine! On the machine were the same as ever, that is, when the scan worked. So the problem is to configure the computer again. I do not remember what the technician did the first time!
          I remember only that he could not configure it. In the end I only remember that he has enabled FTP from Windows settings and put the password in my Windows account. I did this procedure but does not work!
          • adriansto
            • 2388
            Post here the configuration report face two with scanning settings.
            • Enzo
              • Jul 2009
              • 413
              this is the report of the machine
              • adriansto
                • 2388
                You don't have defined the path in netork scanning default repository and network scanning template pool
                If you use embedded ftp from WinXP the path is / xxxx or \xxxx.
                / or \ represent C:\Inetpub\ftproot and xxxx is a folder in ftproot folder where user enzo have write and read rights
                Also in WebUI interface of machine you must enter the password for user enzo. This field don't appear in config report but it exist in WebUi interface.
                • Enzo
                  • Jul 2009
                  • 413
                  My friend, the file transfer to my computer does not work!
                  I put as the path: C: but it does not work! Also because it gives me error if I insert other paths, type C:\Documents and Settings\Enzo\Documenti\XEROX (this is the folder where I put the files). I think the problem is in computer that has lost the settings, even if I put all the same settings as before formatting.
                  • adriansto
                    • 2388
                    In this case you must choose scan to home and the path is \xerox.
                    Or the root for ftpuser = enzo need to be c:\........\My Documents.
                    • Enzo
                      • Jul 2009
                      • 413
                      Friend, I fixed it! Basically the settings were right but in my computer was not enabled IIS! Thank you.
                      • Enzo
                        • Jul 2009
                        • 413
                        hello friend. scanning now works. the only thing that is different from before is that now, before I start scanning, it asks me to enter username and password. how can I remove it?
