XEROX 252 quality issue
  • jptaylor45
    • Feb 2012
    • 19
    [Misc] XEROX 252 quality issue
    bad copies.jpgI am trying to fix a problem with a xerox 252. The black has an issue where I am getting fade out line about an inch wide. I replaced the black drum but that didn not fix the problem. I was wondering if the developer unit may have a problem. I usually work on KM not xerox so not sure what to do next.
  • adriansto
    • 2384
    Re: XEROX 252 quality issue
    Post here a sample of defect. One image is more powerful than 1000 words to describe the issue.
    • Milo Wilson
      • 500
      Looks like dirt on the Black/Cyan laser mirrors
      • adriansto
        • 2384
        The faint zone in solid black area is not so evident so the developer unit is ok
        Check BkC ROS or 2nd BTR.
        • xcopytech
          • Aug 2006
          • 1793
          clean black drum erase lamp
          • jptaylor45
            • Feb 2012
            • 19
            Great, now how do I get to the laser mirrors?
            • adriansto
              • 2384
              tt.pdf
              • jptaylor45
                • Feb 2012
                • 19
                are there any instructions on how to get to the laser mirrors to clean them?
                • adriansto
                  • 2384
                  You are KM tech- should to know how to clean laser mirrors.
                  • davidj7
                    • 1107
                    Pull out the drum assembly . You can access the laser mirror glass .if you are lucky , you can see dust on the glass clean it and you are done .
                    Removing the ROS from top is much hell of a task .
                    • jptaylor45
                      • Feb 2012
                      • 19
                      I did remove the drum assy yesterday and cleaned the best I could from under but having the same problem, I am going in from the top today... wish me luck!
                      • davidj7
                        • 1107
                        oh man u do need luck!! good luck from me
                        • jptaylor45
                          • Feb 2012
                          • 19
                          what I need is a diagram of exactly where everything is located. I have manuals on everything else I work on, not this xerox
                          • davidj7
                            • 1107
                            this is the best i can do from the service manual
