docucolor 5000 fault code 10-320
  • nunislav
    Hi, can anybody help me to resolve error code 10-320 on dc 5000,
    may be nvm read/write value ?
  • adriansto
    • 2387
    Re: docucolor 5000 fault code 10-320
    The Fuser Belt Latch Motor failed to start rotating within the required time limit.
    You may need pws tool to troubleshot that
    • ZeusGT
      • 271
      I thought the 010-320 was a fuser overheat fault. Yes, that is a standard NVM over write after the problem is fixed. Agreed about the PWS being there may not be a internal diagnostics service mode.
      CompTia A+ Certified
      CompTia Net+ Certified
      CompTia Server+ Certified
      CompTia Project+ Certified
      OP Scanshare Certified
      • nunislav
        Thanks for the answers ! That realy sound logical, because i replase the fuser belt before that.
        Any suggestions, how can we get a service manual and pws tool !
        • davidj7
          • 1107
          pm me your e-mail address i will ask a person to contact you
