missing network settings DCCS 50
  • pimaxc
    • Jun 2012
    • 11
    So I was running in circles to find a fix for a problem and ended up resetting all of the defaults by going into the service menu by holding 0 and pressing start.
    As a consequence I now no longer have any networking settings.
    Please tell me this is an easy fix.
  • davidj7
    • 1107
    Re: missing network settings DCCS 50
    i think there was a centreware software for that ,must be in the CD's that came along with the machine . I havent touched a machine s DCCS50 in over 5 years my memory is going blank.
    a machine is only as good as your tech : source:screwtape ; the scary one
    • bojans
      • 1313
      Give us more details.
      What was the first problem? When say "ended up resetting all of the defaults" did you mean that you have initialized NVM?
      Do you have Cobra rip?
      What network settings you don't have? You can't set IP address or?
      If you have initialized NVM you have to set up proper settings in NVM for your rip.
      • pimaxc
        • Jun 2012
        • 11
        yes I initialized the NVMs and I'm not sure what RIP I have installed. If it is what I think it is, it's the white unit bolted to the back of it with 3 cables running into the printer. Two white ones on the side and a black one on top.
        • adriansto
          • 2387
          Here at our place exist phones with photocamera. At your place dont exist ?
          • pimaxc
            • Jun 2012
            • 11
            • bojans
              • 1313
              That lower box is cobra rip, but I don' know what is upper box. Will send you settings later when get home.Why did you initialized nvm. What was the problem?
              • pimaxc
                • Jun 2012
                • 11
                Where do I get that info from, I reset the NVMs because I was having the paper come through but no toner come out. Turns out the issue was a broken handle that would not turn so the rollers weren't coming in contact with the drum.
                • bojans
                  • 1313
                  Next time call a tech before you do stupid things. Will send you settings later.
                  • pimaxc
                    • Jun 2012
                    • 11
                    Thank you very much. I know just enough about these things to get myself in trouble.
                    • bojans
                      • 1313
                      You already know how to enter diagnostic (0+start 6789)
                      Find NVM Read/Write and set following locations
                      NVM
                      702-031 1 = DFE 60 = Cobra
                      702-032 30 = DFE 60 = Cobra
                      702-037 0 = DFE 15 = Cobra
                      702-038 0 = DFE 15 = Cobra
                      You have cobra!
                      Market Code
                      752-001
                      0
                      = FX Japan
                      1 = AP Asian Pacific
                      2 = NASG North America
                      3 = RX Europe
                      Configuration of Machine
                      752-008
                      0 = Copier 2 = Copier, Printer, Scanner 4 = Printer
                      Configuration Page
                      759-004 0 = DFE 1 = Cobra to fix no print or Slow Print/Configuration Page
                      Good luck
                      • pimaxc
                        • Jun 2012
                        • 11
                        that did not seem to give me back my ip configuration settings
                        • bojans
                          • 1313
                          You have to set up ip config.
                          Press button with key above, password is 2222 or 22222
                          find network settings
                          set up your ip address
                          • pimaxc
                            • Jun 2012
                            • 11
                            It should be under Machine setup correct? The options are not on the machine. The key is supposed to bring up the Auditron and because the Auditron is not setup pressing the key button does nothing for me.
                            • bojans
                              • 1313
                              1.) Press the [Administration] button located on the copier/ printer Control Panel.
                              2.) Press [Tools] on the copier control panel
                              3.) Enter the password "11111"
                              4.) Press [Machine Setup]
                              5.) Press [IP address]
                              II.) To change the IP address:
                              1.) Press [Change Settings]
                              2.) Enter the IP Address NOTE: The IP address must be entered with leading zeroes, for example, the IP address 13.145.200.4 must be entered as 013145200004.
                              3.) Press [Save]
