missing network settings DCCS 50
  • pimaxc
    • Jun 2012
    • 11
    #16
    Re: missing network settings DCCS 50
    IP Address is not listed in this menu.
    • bojans
      • 1313
      #17
      Did you set up these settings? Check it again. New value is confirmed with Start button
      702-031 to 60
      702-032 to 60
      702-037 to 15
      702-038 to 15
      • pimaxc
        • Jun 2012
        • 11
        #18
        yes, just double checked in the NVM Read/Write panel. I also double checked the other values you gave me. They are all correct
        • bojans
          • 1313
          #19
          Turn off machine and reseat all cables from cobra to machine.
          If that doesn't solve problem maybe you have to reload Cobra software.
          • pimaxc
            • Jun 2012
            • 11
            #20
            Reseating the cables did not work.
            • adriansto
              • 2388
              #21
              700-099 to 1
              702-031 to 60
              702-032 to 60
              702-037 to 15
              702-038 to 15
              710-062 to 0
              710-063 to 0
              715-125 to 1
              749-030 to 1
              752-001 to 3 =2 for northamerica
              752-008 to 2 (2=copier/printer,4=printer only)
              759-051 to 1
              759-004 to 0
              759-053 to 1
              759-054 to 1
              759-093 to 0
              759-094 to 0
              775-738 to 0
              775-887 to 15
              990-302 to 0
              These are the nvm settings for Cobra1 controller for RX european market
              • pimaxc
                • Jun 2012
                • 11
                #22
                That fixed it, thank you both soo much. I'll make sure to ask here first if I have any other issues crop up.
                • bojans
                  • 1313
                  #23
                  Adi thanks for jumping in.
                  I was out of ideas
                  • adriansto
                    • 2388
                    #24
                    Welcome !
