Xerox wc 5222 - scan function
  • savi0r
    • Sep 2010
    • 363
    Hi all. I need to know how to install and use this copier as a scanner. I need it to scan from a local PC, connected to the copier with an usb cable.
  • livewire
    • Sep 2011
    • 608
    Re: Xerox wc 5222 - scan function
    Scan to usb is impossible. To be able to scan you need Printer PWB and the HDD.
    Printer PWB 540K08781
    Scan features are:
    File formats: PDF, TIFF, Multipage TIFF, XPS;
    Features: Scan to Mailbox, Scan to PC, Scan to Home, Job Flow Sheets
    Optional:
    Black and white Scan to Email Kit (w/ LDAP and Mailbox functionality),
    Black and white Network Scan Kit, Scan to PC Desktop
    • savi0r
      • Sep 2010
      • 363
      Scan features are:
      Optional:
      The copier has all the options installed. It works even as a network printer. So how do i use it as a scanner on a local PC?
      • livewire
        • Sep 2011
        • 608
        savi0r,
        You write that it is a copier.
        "I need to know how to install and use this copier as a scanner."
        I did not know that there is a printer.
        Try it with a crossover cable between the machine and computer.
        In this connection works as priter.
        Scanning with a crossover cable - I do not know.
        Try it.
        • adriansto
          • 2385
          Probabil ai doar optiunea scan to email si scan to mailbox.
          Nu poti scana direct in pc. Trebuie sa setezi aparatul sa scaneze in mailbox si de acolo extragi, prin retea ,fisierul in pc. Sau scan to email si ai fisierul in inbox-ul din mailul tau
          • livewire
            • Sep 2011
            • 608
            Translate.
            Perhaps you only option scan to email and scan to mailbox.
            You can scan directly into PC. You must set the device to scan the mailbox
            and there extract, the network file in PC.
            Or scan to email and file of the mail in your inbox.
            adriansto, I hope that no problems.
            • adriansto
              • 2385
              Translate.
              Perhaps you have only option scan to email and scan to mailbox.
              You can't scan directly into PC. You must set the device to scan the mailbox
              No problem. Now is the right translate !
              • savi0r
                • Sep 2010
                • 363
                Hi all. Adriansto told me to folow the steps that are specified in the brochures on the xerox website. I tried today and i managed to scan and extract the files to the pc, using mailboxes. Thank you all for your help.
                • savi0r
                  • Sep 2010
                  • 363
                  Hi all. I revive this old thread with an issue i'm having. So, i need to setup a xerox 5222 for network scanning. Problem is when the machine starts, i don't have the "scan to email" and "scan to mailbox" options. For what i know, the scan kit must pe installed using a certain password written in the original documentation that came with the copier. My question is this : if the customer lost the cd's and documentation, how can i manage to install the scan function? What exactly is that password written in the documentation that came with the machine? Can it be found somehow? Is it a password that's specific for each machine?
                  • dorez
                    • Feb 2013
                    • 73
                    Hi,
                    Try using the following link: (May Not ALWAYS work but worth a try)
                    Hope This Helps ..
                    • savi0r
                      • Sep 2010
                      • 363
                      It seems interesting. Gonna try it tomorrow. Anyway, what does the site display after you enter the serial number? Any chance that i can get my password?
                      Sorry. Just checked it out a little bit better. It seems that if i enter the serial number , it will give me the keys for activation. Dorez, thanks a lot man. I really owe you one. Saved my a$$.
                      • avimz
                        • Feb 2011
                        • 8
                        go to maintenes menu by typing 0 to six secneds the press the satart key (green key ) THE THE PASS 6789 AND ENTER
                        the lcd becaome dark you in mamintanes mod
                        1. go to tools
                        2.go to maintenece
                        3. find ther the "software option "
                        4. on the keboard type this code : #nBZpeDYYHOY
                        THEN REBOOT THE MACHINE AND ALL THE SCANING WILL BE OPEN
                        YOU MUST TO INSTALL PRINT KIT AND HDD
                        • Exok
                          • Jun 2011
                          • 750
                          Just go to Xerox Document Management, Digital Printing Equipment, Business Process Outsourcing
                          Select Support and Drivers
                          Enter 5222 in the Search window
                          Select your machine
                          Select Documentation
                          Select User Guide
                          Follow directions
                          Scan to your heart's content
