xerox workcentre 5225 116.331 error code
  • javier4065
    • Feb 2007
    • 251
    My problem is the following. Xerox workcentre 5225 display says 116.331 What Can I do to solve it . thanks.
  • livewire
    • Sep 2011
    • 608
    Re: xerox workcentre 5225 116.331 error code
    Switch the power off, remove the HD, switch the power on, wait until machine warming up.
    Switch the power off, reinstall the HD, and switch the power on.
    • zagrex
      • Dec 2011
      • 63
      116-331 Invalid Log Information RAP
      Description
      A log error is detected.
      Initial Action
      Power Off/On
      Procedure
      Remove the HD, switch off the power, reinstall the HD, and switch on the power.
      If the problem persists perform Hard Disk Diagnostic Program.
      If the problem persists replace the HDD ( PL 9.2).
      If the problem persists, replace the ESS PWB ( PL 9.2).
      Purpose
      NOTE:
      HDD initialization using the UI-Diagnostic is only for Partition A.
      Procedure
      1. Access Diagnostic Routines.
        1. Enter UI Diagnostics ( UI Diagnostic Mode).
      2. Select Sub System.
      3. Select Initialize Hard Disk and select Partition A.
      4. Press the Start button and select Yes.
      5. When Partition A has been initialized is displayed, select Confirm.
      NOTE:
      After the above procedure, Partition A will be initialized.
      • javier4065
        • Feb 2007
        • 251
        Thanks, I removed hdd disk and display says 016.210. How can I enter to service mode in this model, Maybe press "0" like others xerox models. thanks.
        • livewire
          • Sep 2011
          • 608
          Yes,
          Press and Hold (0), then (Start)
          Passcode: 6789
