Xerox Workcentre Pro 65 Jam area 2
  • mrfuser
    • 1626
    Okay, replaced feed rollers, seemed to work for a while, then it jams from paper deck on side going into machine. Any ideas?
    Kelly
  • Enzo
    • Jul 2009
    • 413
    Re: Xerox Workcentre Pro 65 Jam area 2
    that machine gave me a lot of problems until I replaced a sensor in the developer. From that moment on, the sheets will not jam more in the area2.
    • CopierTechofOmens
      Agitating Artificer
      • 268
      What Jam code are you getting?
      sigpic
      • mrfuser
        • 1626
        Found a broken tension spring at entrance to copier that pulls down top of feed path to press against lower part.
