WCP 232 toner / developer difficulties
  • jbenedetto
    • Jul 2025
    My Workcentre Pro has been acting up. When I try to print or make copies, the copies come out very light, and then after about 6 prints, the printer stops and says "Toner Sensor Error" or something to that effect. I go into the diagnostics and it turns out the toner sensor is reading "HIGH". According to the service manual this means toner concentration is LOW.
    So after I unlock the toner sensor, I go into component control and look at the toner sensor and run the toner dispenser. After running the toner dispenser, the sensor goes back to "LOW" and I can run prints again. After about 6 prints, the printer stops and I get the toner sensor error again. Repeat ad nauseum.
    Do you have any ideas? I really don't want to spend a couple hundred on a new developer module, and I have a feeling there is a simpler solution.
    Many thanks!
  • anulu
    • Sep 2012
    • 20
    Re: WCP 232 toner / developer difficulties
    1. The toner dispenser gear is worn, glue it, or replace
    2. the devhousing assy bearing is dead, which kills the gears of the augers
    • jbenedetto
      Thanks for the reply. I took the dispenser off and examined all the gears. Every gear looks as good as new. I'm not sure how to get at the bearing. Is there a document for servicing the developer module?
      I should point out that this problem started after I dusted the inside of the unit with compressed air.
      J
      • adriansto
        • 2387
        J
        Electrostatic discharge. May be you blowup the toner sensor from dispenser module.
        Check if the toner sensor works
