Xerox 7665 "Network Scaning" function missed . . . .
  • Alex5213
    • Dec 2011
    • 26
  • adriansto
    • 2388
    Re: Xerox 7665 "Network Scaning" function missed . . . .
    The net scanning feature is an option for this machine. To enable ( reenable ) this option you must use SIM card who came with this feature option.
    • Alex5213
      • Dec 2011
      • 26
      • Milo Wilson
        • 503
        Is there a scan to email function enabled on your machine also? If there is then maybe the option was disabled in administration settings. Are there 2 PCI cards in the controller? If there are then maybe the one with the wide cable came out of it's slot. If there is just a firewire card in the controller then you might have a bad ram stick. What is the software level of the printer?
        • Alex5213
          • Dec 2011
          • 26
          There is no scan to email enabled and never was, there is only one PCI card in the controller with firewire conector, the software is : 040.33.53050 One more thing : when this machine was working fine i take out the Hard Drive and make an "Image" of the whole drive, i already re-load the whole image into the Hard Drive and still the same problem "Network scaning" function missed . Thanks for your help !
          • adriansto
            • 2388
            Pull out tray1 and one the right side of the tray is a little cover. Open the cover and in storage compartment will see two sheets of paper and the sim card. You also may try same thing on tray2
            • Alex5213
              • Dec 2011
              • 26
              I found the sim cards !, i have 3 sim cards, scan/email ( 301k15390) , JBA ( 301k15420 ) and B1 Key ( 98S04876 ). What i need to do with them ?
              • adriansto
                • 2388
                Back left side of the machine where the cables go on you'll find a place to insert the sim. Insert the scan/email sim and the green led will flash. After that you can remove the sim and the scan option should be available on UI display.
                • Alex5213
                  • Dec 2011
                  • 26
                  It Works !, Thank you very much for your help !
