Xerox 7665 "Network Scaning" function missed . . . .
Re: Xerox 7665 "Network Scaning" function missed . . . .
The net scanning feature is an option for this machine. To enable ( reenable ) this option you must use SIM card who came with this feature option. -
Is there a scan to email function enabled on your machine also? If there is then maybe the option was disabled in administration settings. Are there 2 PCI cards in the controller? If there are then maybe the one with the wide cable came out of it's slot. If there is just a firewire card in the controller then you might have a bad ram stick. What is the software level of the printer?Comment
Pull out tray1 and one the right side of the tray is a little cover. Open the cover and in storage compartment will see two sheets of paper and the sim card. You also may try same thing on tray2Comment
I found the sim cards !, i have 3 sim cards, scan/email ( 301k15390) , JBA ( 301k15420 ) and B1 Key ( 98S04876 ). What i need to do with them ?Comment
Back left side of the machine where the cables go on you'll find a place to insert the sim. Insert the scan/email sim and the green led will flash. After that you can remove the sim and the scan option should be available on UI display.Comment
It Works !, Thank you very much for your help !Comment
