PLease help with reset procedure. Changed a magenta drum and this came up: 009-380. Please if you have a manual I would like one please.
Xerox 7335 009-380 code
Re: Xerox 7335 009-380 code
The Yellow ATC Sensor detects a low TC (toner concentration).
Initial Action
- Check that Toner/Developer is present.
- Check the Yellow ATC Sensor for contamination. Ensure that the sensor is seated correctly.
NOTE:
To clear this fault, enter Component Control and set the value of NVM location 752-109 to 0.
This can be caused by many things. I've seen broken Drum contacts from improper drum installation causing Developer bead carryover. Toner dispense motor assy's failing. Developer Housing failure. DVHVPS failure.sigpic - Check that Toner/Developer is present.
Initial Action
NOTE:
This can be caused by many things. I've seen broken Drum contacts from improper drum installation causing Developer bead carryover. Toner dispense motor assy's failing. Developer Housing failure. DVHVPS failure.Comment
Press 0 for 5" and press start (0 still pressed),
6789 in log ,
machine status (blue buttons),
Tools,
System settings ,
common setings,
Maintanance & diagnostic,
NVM read/write.
put the 752-109 to 0.
If it doesn't help It is beter to call tech.Comment
