Xerox 7335 009-380 code
  • Jude
    • Oct 2009
    • 256
    PLease help with reset procedure. Changed a magenta drum and this came up: 009-380. Please if you have a manual I would like one please.
  • CopierTechofOmens
    Agitating Artificer
    • 268
    Re: Xerox 7335 009-380 code
    The Yellow ATC Sensor detects a low TC (toner concentration).
    Initial Action
    • Check that Toner/Developer is present.
    • Check the Yellow ATC Sensor for contamination. Ensure that the sensor is seated correctly.
    NOTE:
    To clear this fault, enter Component Control and set the value of NVM location 752-109 to 0.
    This can be caused by many things. I've seen broken Drum contacts from improper drum installation causing Developer bead carryover. Toner dispense motor assy's failing. Developer Housing failure. DVHVPS failure.
    sigpic
    • Jude
      • Oct 2009
      • 256
      Initial Action
      NOTE:
      Not a xerox tech so please PM the procedure?
      • nilak
        • Aug 2010
        • 72
        Press 0 for 5" and press start (0 still pressed),
        6789 in log ,
        machine status (blue buttons),
        Tools,
        System settings ,
        common setings,
        Maintanance & diagnostic,
        NVM read/write.
        put the 752-109 to 0.
        If it doesn't help It is beter to call tech.
