Xerox 2636 error 09-456
  • Tinochka
    • Jul 2012
    • 127
    [Error Code] Xerox 2636 error 09-456
    Hello.
    Xerox 2636 doesn't start up.
    Does anybody faced this problem?
    and WCP Diagnostic says
  • Tinochka
    • Jul 2012
    • 127
    Re: Xerox 2636 error 09-456
    I've heard the cause could be the battery (m4t28-br12sh1) on CCM.
    Does anybody know how to change the battery. It should be special procedure?
    • bojans
      • 1313
      Just replace old battery with a new one. There is procedure to setup machine BIOS. This is for your second error code 3-338.
      For error 9-456 check HFSI and reset counters.
      • CopierTechofOmens
        Agitating Artificer
        • 268
        09-456 is DV end of life.
        Also might want to upgrade software. Reseat all PWB's, cables and memory in the ESS.
        sigpic
        • Tinochka
          • Jul 2012
          • 127
          The battery has 2.7V. So I think, first I should change the battery, and then I will see.
          • bojans
            • 1313
            It's good voltage.
            • bojans
              • 1313
              Check this
              http://www.copytechnet.com/forums/xe...-help-plz.html
              Follow procedure posted by adeyemi
              • Tinochka
                • Jul 2012
                • 127
                Ok.
                I'll try.
                thank you very much!
                • bojans
                  • 1313
                  You're welcome and good luck
                  • Tinochka
                    • Jul 2012
                    • 127
                    After I changed the battery, the WCP Diagnostic doesn't connect.
                    • Tinochka
                      • Jul 2012
                      • 127
                      After restore all NVM dc361 many times and replace the battery - c2636 finally works ok!
