Code 077-909
  • Copisat
    [Error Code] Code 077-909
    I've a big problem, the code is persistent. the machine has had a multiple paper jam between bypass (5) tray to the fuser. I removed and tried with another fuser and still gives me error. I've also tried to power cycle.
    Help me please. Thanks
  • bojans
    • 1313
    Re: Code 077-909
    Which model you're talking about?
    • Copisat
      Re: Code 077-909
      Originally posted by Copisat
      I've a big problem, the code is persistent. the machine has had a multiple paper jam between bypass (5) tray to the fuser. I removed and tried with another fuser and still gives me error. I've also tried to power cycle.Help me please. Thanks
      The machine is Xerox Color 550/560
      • 123cbboy123
        Re: Code 077-909
        The fault code says that you have a paper under registration assy, check or clean from dust if you have.
