System Fault 9-343
  • Kopy Kat Mandy
    [Error Code] System Fault 9-343
    I have been battling with my Doc 12 for days now! I am getting a system fault 9-343 upon turning on the machine, I am at a loss. I have tried all the "tips" given to me to rectify this issue with no successes. At first the machine was making a grinding sound, so I thought that it was the clutch, however I cleaned out the machine and cleaned all the sensors, this helped with the grinding noise, but i continue to get the system fault upon start up! any ideas? anything would help at this point!.
  • Enzo
    • Jul 2009
    • 413
    Re: System Fault 9-343
    The code is: "a contact failure on the BTR roller". The machine is not seeing good contact to that roller.
    • Kopy Kat Mandy
      I do understand that, However I don't know how to rectify this issue. how do I fix this?
      • adriansto
        • 2387
        Read service manual and you will ...
        • Kopy Kat Mandy
          easier said then done .. I don't have one!.
          • JustManuals
            • Jan 2006
            • 9838
            Paul@justmanuals.com
            • johnner66
              • Mar 2009
              • 265
              on copier behind there is a clutch that rotact the roller try check the clutch here we do it it work goodluck
