Xerox 5632
+ More Options
Posts
  • Tinochka
    • Jul 2012
    • 127
    Xerox 5632
    Hello
    Does anybody know, is the controller software for XEROX 5632 the same as for XEROX WC PRO 55 ?
  • adriansto
    • 2383
    Re: Xerox 5632
    Never !
    • Tinochka
      • Jul 2012
      • 127
      Re: Xerox 5632
      so, does anybody can share controller software for me pls?
      • seansbar
        • Dec 2010
        • 198
        Re: Xerox 5632
        Did you go to Xerox's webpage? It is there.
        • Tinochka
          • Jul 2012
          • 127
          Re: Xerox 5632
          Can I reinstall it from Alternate boot?
          • xeroxsharp
            • Nov 2008
            • 270
            Re: Xerox 5632
            YES,check your email in 30 min.
            br
            • Tinochka
              • Jul 2012
              • 127
              Re: Xerox 5632
              Thank you
              • xeroxsharp
                • Nov 2008
                • 270
                Re: Xerox 5632
                Originally posted by hmelo
                Its possible???
                Can You give me the metod???
                Using the Alternate boot???
                thanks
                Do you have GSNLock Client and XEROX PWS DIAGNOSTIC TOOLS instal on your laptop?
                If not,you can not use alternate boot.
                BR
                • xeroxsharp
                  • Nov 2008
                  • 270
                  Re: Xerox 5632
                  Yes, I have.
                  I just curious about install a DLM file ( that xerox provide in web page ) using the alternate boot TOOL.
                  regards
                  Please send me PM with your e mail addres.
                  I could share SW on dropbox.
                  BR
                  • seansbar
                    • Dec 2010
                    • 198
                    Re: Xerox 5632
                    There seems to be confusion, the software on the xerox public page is general releases. It is supposedly stable and what is recommended usually. Form the GSN website, you can download spars, but those are made to address issues and may introduce other issues, thus only apply spars if it helps individual issues.
                    Now for altboot. Altboot process is necessary for:
                    1. 'downgrading' to a lesser version
                    2. to fix software corruption on NC
                    3. When replacing the HDD.
                    Altboot software is also obtained from GSN and is a 'package' that also has the image that allows you to boot NC from PWS and reload the software. The 'package' has a .dlm file in it. I recommend using the .dlm that comes with the 'package'. Once you have done an altboot, you may then upgrade the the latest .dlm you wish to use. This can be done thru CWIS.
                    Now the original post did not specify altboot, therefore I did not suggest searching GSN.
                    • Tinochka
                      • Jul 2012
                      • 127
                      Re: Xerox 5632
                      BR
                      Yes I have it on my laptop. But I have it for CC232-WCP275. Is it possible to use Alternate Boot for CC232-WCP275 with Inst/NC/diskimg files for 5632?
                      I guess the Alternate Boot is the same for CC232-WCP275, WCP35-55 and 5632 ?
                      • xeroxsharp
                        • Nov 2008
                        • 270
                        Re: Xerox 5632
                        Check you email!
                        • Tinochka
                          • Jul 2012
                          • 127
                          Re: Xerox 5632
                          Check you email!
                          Today I install the software on my laptop. After that I install controller software. Finally the controller is working now.Thank you!
                          P.S.
                          I had no faults only with " 56xx PWS USB Drv "
                          Thanks.
                          • xeroxsharp
                            • Nov 2008
                            • 270
                            Re: Xerox 5632
                            t7253-05.doc
                            P.S.
                            Thanks.
                            "NC performance issue"
                            • adriansto
                              • 2383
                              Re: Xerox 5632
                              Wrong conclusion !
