DC1632 unknown problem
  • Tinochka
    • Jul 2012
    • 127
    Hello.
    I have unknown issue on DC1632.
    It starts up until 5th dot blinking, after that I see this (see pictures). I can't connect PWS to the printer
    I tried to reseat all modules but nothing helps
  • bojans
    • 1313
    Re: DC1632 unknown problem
    Check Fuser Fan! or Rear Fan
    • Tinochka
      • Jul 2012
      • 127
      Both of them works fine
      • bojans
        • 1313
        Then check IBT Belt patch.
        • Tinochka
          • Jul 2012
          • 127
          Checked. Fine.
          It looks like some boot-up failures, because I can't connect pws.
          • bojans
            • 1313
            Open front door, then try to enter diagnostic.
            • bojans
              • 1313
              These are Special Boot Modes. Try one by one and check if you can enter diagnostic.
              GP3.pdf
              • Tinochka
                • Jul 2012
                • 127
                I did that. I entered in diagnostic mode, but I can do nothing
                • bojans
                  • 1313
                  Is there any error code?
                  • Tinochka
                    • Jul 2012
                    • 127
                    No error codes. Nothing more except that I posted.
                    • xeroxsharp
                      • Nov 2008
                      • 270
                      I will do that: 1.HDD initialization
                      2.unplug netw.cabl and PowerOFF/PowerON WC
                      or 3. maby you need higher version of diag tool 3.10
                      Good luck
                      BR
                      • Tinochka
                        • Jul 2012
                        • 127
                        Good luck
                        BR
                        There is no HDD in this mashine. It worked without HDD. There is only harness for HDD.
                        I don't have 3.10 version
                        Is there any way to upload firmware to the printer?
                        • xeroxsharp
                          • Nov 2008
                          • 270
                          tinocka.doc
                          • Tinochka
                            • Jul 2012
                            • 127
                            [ATTACH]18217[/ATTACH]
                            Thank you.
                            I've already done it. But nothing helps. Today I'm gonna try to replace PWBs one by one. Hope I can figure out which one is defective.
                            • johnner66
                              • Mar 2009
                              • 265
                              how about the exposure lamp is this light and is this move 2 time then go to home if no then is the ccd problem good luck
