DC12 will not print on glossy paper
+ More Options
Posts
  • Sam314
    • Jun 2025
    Hello,
    I have a older Xerox Docucolor 12. I can print fine on plain paper but not on glossy paper. I found that the fuser oil was empty, filled it, tried printing 20 to 30 more sheets and still the same problem. If I run a sheet of plain paper and print a blank page after printing a large image on glossy paper, the image is ghosted on the back side of the plain paper.
    I am a startup one man business. Should I just replace the entire fuser cartridge?
    Any suggestions will be greatly appreciated!
    Thank you,
    Sam
  • bojans
    • 1313
    Re: DC12 will not print on glossy paper
    If it was out of oil, I would first check oil pump. In Component control 10-033!
    But if you have entire Fuser assy, replace it.
    • Sam314
      Thank you!
      Can you tell me how to get to Component Control 10-033?
      • Sam314
        OK I found the instructions on the 10-033 in the service manual. Thank you again!
        Sam
        • bojans
          • 1313
          If you have SM you can find how to enter diagnostic and component control.
          Cheat front interlock and start 10-033. If the pump doesn't operate replace it.
