dc 250 yellow ghosting
  • bojans
    • 1313
    [CQ] dc 250 yellow ghosting
    Hi folks,
    Got this problem with dc 250, ghosting/offseting only with yellow. After changing developer station it worked for a week, then happens again.
    Any suggestions
  • adriansto
    • 2384
    Re: dc 250 yellow ghosting
    Do a Maxsetup and after that compare charge voltage and bias voltage for Y with same voltage for C and M
    • bojans
      • 1313
      You suspect on HVPS?
      • adriansto
        • 2384
        Not only. As you know in xerographics process the charge and bias voltage depends from many parameters.
        After max setup these parametres must be pretty equals for Y,C,M. Also the voltage for charge and bias.
        You must do a measurement and see if there is signifiant difference.
        • bojans
          • 1313
          Thank you.
          Customer is far away, so need couple days to arrange visit.
          Will check and inform.
          • JustManuals
            • Jan 2006
            • 9838
            Paul@justmanuals.com
            • bojans
              • 1313
              thank you
