Phaser 7760 RAM error message
  • Scarecrow
    • Oct 2010
    • 234
    Getting a RAM error message after trying to reload firmware. Machine seemed to reboot during the reload process and I am currently unable to clear the RAM error - unable to get into diagnostics. The original problem was a dead machine and I found the image processor board with five volts shorted. Was not able to get the machine back to normal after replacing that board: continuous reboot, install metered black cartridges message. Tried to reload firmware to solve this issue.
    Anybody have any ideas? Thanks! Glenn
  • JustManuals
    • Jan 2006
    • 9838
    Re: Phaser 7760 RAM error message
    Sounds like you're f_cked.
    • Scarecrow
      • Oct 2010
      • 234
      I've been that way serveral times in the past - most of the time there is an availabnle solution. If I find it, I will post it. Or maybe someone will help out.
      Glenn
      • Scarecrow
        • Oct 2010
        • 234
        [QUOTE=Scarecrow;327641]I've been that way serveral times in the past - most of the time there is an availabnle solution. If I find it, I will post it. Or maybe someone will help out.
        Turned out to be bad ram (!). Evidently, there are at least 2 image processor bds.One will take only 1 stick, there will accept 2. If I put the good IP/w the 2 good ram sticks in the bad 7760, the same message will come up - fooled me. It had 2 bad ram sticks and a shorted ip brd.
        Glenn
