Apeos 4300 scan to pc slow
+ More Options
Posts
  • brianho80
    • Sep 2009
    • 198
    Hi,
    does anyone ever asked by customer SMB scan from apeos 4300 to PC take more than 12 sec?
    Comparing with other brand, doing SMB scanning, once user hit start and scan, file will transfer to PC within 5 sec.
    anyone know why?
  • Texiun
    • Sep 2012
    • 24
    Re: Apeos 4300 scan to pc slow
    Dependent on many things!
    Have you got Spool to HDD set for SMB?
    Scanning DPI? 200/300/600?
    Image Quality? Set to high or the "Default" Level?
    Let me know!
    • brianho80
      • Sep 2009
      • 198
      Hi Texiun
      i set SMB Spool to Hard disk
      DPI = 200
      Impression = Normal.
      any other thing i need to look into?
      • Texiun
        • Sep 2012
        • 24
        If you have only just set the SMB Spool to HDD I would imagine your scanning should be fairly quick by now
        Let us know if it's still slow.
        • brianho80
          • Sep 2009
          • 198
          was it supposely quick once we set SMB spool to hard disk?
          because next to it has DCC 450, without setting SMB Spool to HDD, the transmission speed to pc is a lot faster than apeos 4300
          • Texiun
            • Sep 2012
            • 24
            Is the SMB Spool on the 450 set to Memory 32mb? If so thats why
            • brianho80
              • Sep 2009
              • 198
              it set to 256mb.. Well, i will change apeos 4300 SMB setting to this, perhaps it can transmit a lot faster.
              • Texiun
                • Sep 2012
                • 24
                No no, They should both be set to spool to HDD, Specially LPD, As well (Using LPR port 515 for printing) If LPD is set to HDD also customer wont experience slow prints
                • brianho80
                  • Sep 2009
                  • 198
                  Hi Texiun, today i used my iphone timer to count the transmission time from machine to Pc. It took 38 sec to complete one job.
                  i have tried 3 different setting like below, all need 38 sec to complete transmit to PC.
                  SMB Spool -> 1,Hard Disk
                  -> 2, Off: 1024MB
                  -> 3, memory: 2.35MB
                  Do you have any other ideas what to do next?
                  • Texiun
                    • Sep 2012
                    • 24
                    Hmmm....Firewall? Seems Unlikely but not uncommon. Norton has a tendancy to slow things down like that. Have you tried scanning it to your laptop? And seeing the speed from there? Isolate it from the customers network and test between your laptop and the machine
                    • brianho80
                      • Sep 2009
                      • 198
                      tested from notebook direct with cross cable. also the same... does the board having problem? or can we set the ethernet transmission speed?
                      • tieuquyen
                        • 33
                        Did you reset NVM, then setup network again and make a test, may be problem at the NVM memory
