5675 vs 5655 controller?
  • mrfuser
    • 1611
    Does anyone have a 5675 controller for sale or do you know if a 5655 controller will work?
    Thanks all
    kelly
  • tieuquyen
    • 33
    Re: 5675 vs 5655 controller?
    Thanks all
    kelly
    May be its same each other, what is EPROM on ESS name? If the eeprom on both machine is the same, you could swap it on
    • xeroxsharp
      • Nov 2008
      • 270
      Thanks all
      kelly
      Do not know for SCB controller,but it is the same controler from 38-87ppm if you copier need MCB controller intalled on back of copier.
      X5665-5687 mashines have colour scanning!!!!!!!!!!
      Sorry,do not have it for sale
      BR
      • surajsingh
        Bios version is different for MBC machine and for sbc NC is same.
        • Exok
          • Jun 2011
          • 750
          If they are both the same type (Tag-40 or single board controller - controller is integrated in the sip tray), (Non Tag-40 or multi board controller, controller mounts to the back of the machine) then yes you can interchange them from a 5675 and 5655.
