Magenta Dots DC250
  • afropro
    • May 2012
    • 61
    Magenta Dots DC250
    Hi there, I am having this little dots when I print A3 format, what can cause that, the drums are brand new, the fuser also, the magenta developer with the tank is also new. I have opened the transfer belt to see if there is any mark there but no, so I dont have a clue where to look. Any suggestions.
  • copytech200X
    • 264
    Re: Magenta Dots DC250
    [ATTACH=CONFIG]18918[/ATTACH]
    Imsuggests do panic stop to confirm where is the cq defects before transfer or after ?
    • afropro
      • May 2012
      • 61
      Well I don't know to do this panic stop, how it is performed.
      • copytech200X
        • 264
        when u print just wait machine run for few seconds eg 5 to 8 sec then u open the front door of the machine to chk the cq and confirm problem lies from ibt belt image or after ibt image?if cq defects happen at ibt image the problem lies to ibt ,drum and 1st transfer .
        • afropro
          • May 2012
          • 61
          I did the panic open, and the paper before entering to fuser had the same dots, so where do they come from.?
          • bojans
            • 1313
            Stop it a bit faster and check drum, and IBT.
            You can also notice that the same dots are repeating. What's the distance between same dots?
            • copytech200X
              • 264
              how abt image on ibt belt or u can measure the distance repeat the mag dot from here u can know which roller defects as each of roller got diameter.
              • afropro
                • May 2012
                • 61
                I did as you sad so, I opened the IBT and the dots where there, then i opened the magenta drum and I have noticed those small dots on the green roller so they are coming from drum, What could have caused do damage the drum like that, it has not been a while since i have changed the drum, it is brand new, can it be from the developer, i have changed it recently, the magenta developer tank and the developer.?
                • bojans
                  • 1313
                  Did you try to clean those dots from drum? Or it's physical damage ?
                  • afropro
                    • May 2012
                    • 61
                    Well, i am afraid to clean them, hoping that I do more damage, what is the best thing to use for cleaning those parts, I mean what kind of tissue, or what chemical?
                    • bojans
                      • 1313
                      For cleaning you can use cotton cloth with some water. It's not so sensitive!
                      For chemicals you can try metal polish liquid.
                      • knightfall
                        • Jul 2006
                        • 633
                        check b&w copy do you see the dots? if you don't then it cant be the itb or the transfer roller then check the magenta charge roller or there may be a dot on there or the drum. try cleaning with water or alcohol and a cotton rag or cotton ball, if on the drum or charge roller and wont come off then a new image unit is required.
                        good luck
                        Get your facts first, and then you can distort them as much as you please.
                        • copytech200X
                          • 264
                          Tis model drum is OPC type hard to clean and cause of wear of drum got few reasons .customer environment like room temperature cause developer material or toner hardened ,i suggests try to use coffee filter to filter hardened developer or replace new toner Cartdrige .
                          • afropro
                            • May 2012
                            • 61
                            Well guys I have tried cleaning the both rollers on the drum unit, but the small dots where still there, it seems it is damaged and cannot be removed, so thanks for all suggestions, i have another question, what could have caused to take damage like that, it is a brand new drum, i have printed maybe around 200-300 prints not more, so i am trying to find what caused that, i doubt in developer, but I don't know so if anyone had this kind of problem and find it where it came from maybe could share with us.
                            • Milo Wilson
                              • 503
                              Contaminated toner in the developer housing. Remove toner cartridge and replace developer material
