docu color12 stuck in power saver mode
  • jhonson
    • Jul 2025
    As soon as the printer switched on, it's in the Power Saver mode. Tried pressing all button, open and close all drawer and the printer doesn't wake up.
    Please help.
  • TzALbg
    • Dec 2007
    • 111
    power save
    you have to push end hold for a 2 seconds green buton located in the upper right side of UI.
    • jhonson
      Power saver
      Yes I tried to press green bottom for 2sec but still on....
      • jhonson
        Yesterday
        I prined yesterday, it was fine but today this thing happens
        it first time.
        • jhonson
          power saver button
          I know that if the printer being idle for little whil it will automatically into power saver mode and wakes up if you press the power saver button.
          However, this one is very strange. tried switched off and on and the machine is straight into powersave mode without any warm up or what so ever. Plus, doesnt want to wake up after pressing the power saver button.
          so, it just sits on the power saver mode.
          Any clue???
          • xcopytech
            • Aug 2006
            • 1794
            dc 12
            check fuses on power distribution pwb
            one of them is blown
            • jhonson
              fuse
              Where is the Fuse Box located? and where can i get the replacemet? thx
              • OES TECH
                • Oct 2007
                • 23
                The distribution pwb is located in the rear of the machine behind the lower cover.
                • TechMate
                  • Mar 2008
                  • 285
                  In addition, if the fuses are all OK last resort would be to check the LOW VOLTAGE POWER SUPPLY (LVPS) and replace if faulty. It is located at the inner-lower back of the machine
                  • Jake2o
                    • Dec 2007
                    • 325
                    I have known this on a couple of machines if the IOT PWB has been disturbed. If you remove and re-seat the plugs on the IOT PWB this may resolve the problem.
                    Be careful though, I did this with one and it corrupted the software. Ensure that you observe static protocols and disconnect it from the mains completely.
                    • TechMate
                      • Mar 2008
                      • 285
                      In our case, these "stuck in power save button" problems were a result of the machine kept in a damp/ high humidity area. It was found out that the LVPS pwb had some sort of oxidation that led to rusty/ shorted connections. Of course prior to these, we have already checked the condition of the IOT PWB, other fuses and certainly have observed static protocols. Software corruption CAN also be a result of incomplete power being supplied to respective PWBs
