Altboot problem with w7 32-bit
  • Oltus
    • Dec 2012
    • 10
    Greetings,
    Does anyone know what might be the reason for altboot not work in W7.
    MFP where I tried to update the firmaware was WS3545.
    Error which I receive is the following:
    Check coms line: reset machine and/or pws application if necessary.
    This problem occurs everytime, after selecting mini-kernel and started uploading the necessary file. All firewall/virus scanners are down.
    I also tried, with vmware player using virtual xp, but the result was the same.
    With normal windows XP I don't have any problem.
    Does anyone know how to solve this problem?
  • adriansto
    • 2388
    Re: Altboot problem with w7 32-bit
    May be your driver for usb to serial adapter dont work fine under Win7. What version of WCPS do you use ?
    • Oltus
      • Dec 2012
      • 10
      With 32- bit W7 we use version 6.1(Black background color) and with virtual machine 32- bit xp version 1.82(White background). We dont't use usb adapter at all, but a direct connect to serial port. Everything works fine untill the firmware choice(ess)... mini kernel uploading etc. works fine.
