Xerox DC12 14-376 error code
  • xcopytech
    • Aug 2006
    • 1794
    ROS is laser.
    I think that multimeter is better solution to check fuses then "eye".
    If you have multimeter check all fuses on power distribution pwb.
    Because if machine do not have 5V, it will look like ROS - laser is broken
    • ewalker
      • 23
      Do you have one to sell me? :P
      • ewalker
        • 23
        fusers all 5V checked (xerox tech)
        • ewalker
          • 23
          #19
          the 160k74412 it´s the Half Tone pwb.. just another part number.
          • xcopytech
            • Aug 2006
            • 1794
            #20
            Then only can try to replace ROS or Halftone PWB.
            But check once more all 5 fuses on PWB.
            They are 5 Ampers/125Volts fuses.
            Back right side on IOT LVPS box
            • ewalker
              • 23
              #21
              ok! thanks
              • ewalker
                • 23
                #22
                • xcopytech
                  • Aug 2006
                  • 1794
                  #23
                  every dc 12 have ROS and halftone pwb, even if dc 12 is only printer without scanner or copier without controller
                  • ewalker
                    • 23
                    #24
                    It wasn´t the ROS. Now the technician asked for a 160K61611 (IOT CPU PWB).. I don´t know where to buy this part or the Half Tone pwb. Any ideas?
                    • xcopytech
                      • Aug 2006
                      • 1794
                      #25
                      this is code for halftone pwb
                      did he try to replace halftone pwb?
                      br
                      • sachin
                        • Jun 2008
                        • 13
                        #26
                        MANUAL
                        I will send the soluation page of 14-376
                        send me your mail id on agrwalsachin@gmail.com
                        • Tinochka
                          • Jul 2012
                          • 127
                          #27
                          Re: Xerox DC12 14-376 error code
                          Hello everybody.
                          I faced the same fault 14-376 on Xerox DC12.
                          I checked all the connections on Half Tone PWB - nothing helps.
                          After that I checked all fuses on distribution PWB - same problem
                          Finally I replaced Half tone PWB - still the same fault
                          • Tinochka
                            • Jul 2012
                            • 127
                            #28
                            Originally posted by Tinochka
                            Hello everybody.
                            The cause is defective IOT CPU PWB. After replacing it, DC12 works fine.
                            I'm going to fix IOT CPU PWB. Anybody has expirience fixing it. This PWB doesn't read serial numbers from HALF TONE PWB. And its impossible to sync s/n numbers.
