Transfer Belt PATCH DC250?
  • afropro
    • May 2012
    • 61
    #16
    Re: Transfer Belt PATCH DC250?
    Originally posted by kalindd
    [ATTACH=CONFIG]19871[/ATTACH][ATTACH=CONFIG]19870[/ATTACH]
    Thanks Kalindd for this great information, I just have one other question, how to find the xerox webstore, I have found this but no patch there, Xerox Official Store : Genuine Xerox Ink, Toner Cartridges, Paper, and Supplies any suggestions.
    • kalindd
      • Jun 2008
      • 192
      #17
      I'm sorry mate. I can't help you with this. I used to work for Xerox and I just ordered the parts.
      May be use a dealer.
      Good luck.
      • davidj7
        • 1107
        #18
        i checked with d&r once and they said the patch was no longer available so i cut a thin strip from the drum packing foil and sticked it to the IBT belt and it ran for a long long time till i had to replace the belt
        a machine is only as good as your tech : source:screwtape ; the scary one
        • afropro
          • May 2012
          • 61
          #19
          Well guys thanks everyone for suggestions and solutions, i have tried the first solution with vinyl, i have cutted in a cutter machine in diameter 1cm x 1cm as the original and today i have replace it, so till now it is working good, i shall see in the future how long it lasts, so once again i am thankful to everyone if something comes up i will ask again guys.
          Regards,
          • Norbert Lamott
            #20
            Hi there guys, I was wondering if anyone can tell where can i buy transfer belt patch, or is there any alternative to change it with a vinyl that is same material as the patch. Because it gives me constantly the erro 042-326, when i clean the patch it works good for a while after it gets dirty a bit then the error comes up. any suggestions.
            first i am a german guy,
            is the belt o.k.?
            get a shim under the sensor to reduce the space between belt and sensor
            did you reset the error code?
            mfg
            Norbert
