Hi there guys, I was wondering if anyone can tell where can i buy transfer belt patch, or is there any alternative to change it with a vinyl that is same material as the patch. Because it gives me constantly the erro 042-326, when i clean the patch it works good for a while after it gets dirty a bit then the error comes up. any suggestions.
Transfer Belt PATCH DC250?
Re: Transfer Belt PATCH DC250?
you will have a hard time looking for it as it is not a consumable but you may be able to use the foil bag from the drums and rubber cement it on the transfer belt, but try ebay first.Get your facts first, and then you can distort them as much as you please.Comment
Yes above picture is useable for ibt patch and cleaning ibt cleaner seal brush last longer.Comment
its hard to tell how thick that vinyl is if its 24lb paper thin than it should work if it's thicker transfer belt might get ripped up later from cleaning blade or blade gets damaged from the patch pushing up on the transfer belt.Get your facts first, and then you can distort them as much as you please.Comment
If I remember right, the part number is 604K45000.
But just to be 100% sure I'm going to check this later today.Comment
Hehehe Nice one, bojans, thank you very much, I am waiting for answer from kalindd. After that if there is no options available i am gonna try that. very good idea by the way.Comment
