CaseServer or Xpro Error when loading WC 7132 SW Download Tool to reinstall system SW
  • akewldewd
    • Dec 2012
    • 83
    I am replacing a bad hard drive on a workcentre 7132 Xerox and I have followed instructions to the T but am stuck at openning the WC 7132 SW download tool I get the error message "You must login to CaseServer or XPRO to verify that GSNLock is active for this application to execute."
    Where can I get the CaseServer or XPRO or is there a way around all this.
    Norm
  • adriansto
    • 2387
    Re: CaseServer or Xpro Error when loading WC 7132 SW Download Tool to reinstall syste
    You must have gsnlock client application started for the 7132 pws tool to works.
    • akewldewd
      • Dec 2012
      • 83
      Thanks where can I get the gsnlock client app?
      • adriansto
        • 2387
        It is part of the main xerox pws application software. You need user ID and password for use it.
        But may be a solution for your problem.
        Send me mail at stoadis@gmail.com
        • max2013
          • Mar 2013
          • 54
          bro...can try this just replace the h/d and off the copier and hold down the 4stop/powersave button and on the copier hold it 3seconds then let the h/d formatt complete and see how ....
          • akewldewd
            • Dec 2012
            • 83
            did you mean the 4, stop and powersave at the same time? I am not in front of a machine right now but I wanted to clearify this. (seems maybe the 4 was a typo).?
            • max2013
              • Mar 2013
              • 54
              yes try it and let me know the result good luck
