Xerox Phaser 3600 ADC Error on display
  • TechGeek
    • 158
    Hey any of you copier guys,
    I have a Xerox Phaser 3600 with an ADC Not Confirm Error on display. I cant find anything in the service manual on this error only they user guide which only says "ADC Not Confirm Error" There is a problem in the ADC (Analog to Digital Converter) of your machine. Any suggestions?
    I originality posted this thread on the printer forum but have not heard any responses yet so i thought i'd give it a shoot here.
  • adriansto
    • 2387
    Re: Xerox Phaser 3600 ADC Error on display
    Most of the time this error is caused by a defect fuser assy.
    If after replacing the fuser the error is still there the next step is to replace main board and lvps but already too expensive.
    • TechGeek
      • 158
      Thanks for the suggestion I had not clue were to even start with this one. After your suggestion of the fuser I took it apart and found that one of the two thermistors had a build up of gunk possibly causing the a inaccurate reading between the two thermistors. So far everything has been working fine.
