Xerox Docucolor 5252 hard drive
  • decmc
    • Apr 2013
    • 7
    Hate to make my first post a "help me" one but here it is anyway :
    I'm working on a Gov. Xerox Docucolor 5252 and am trying to find and/or determine if this copier has a hard drive so I can remove it.
    We found 3 in the Creo CXP6000, does the main unit have any more? If so, where are they hiding?
    Thanks,
    Charlie
  • adriansto
    • 2368
    Re: Xerox Docucolor 5252 hard drive
    Thanks,
    Charlie
    There are four or five hdd in electrical box unit but your confidential data is spread all over the electronic boards of the copier so is more safe to burn this machine !!!!
    Call Xerox and pay them for this task !
    • davidj7
      • 1107
      For the controller ie Creo there are only the 3 hard disks which you saw . On th the machine i believe there are four more hard disks. you can loctae those in PL19.6 IIT electrical box like adriansto said to be on the safe side if you are looking at top secret info its better to remove the IOT boards as well.
      a machine is only as good as your tech : source:screwtape ; the scary one
      • decmc
        • Apr 2013
        • 7
        Thanks for the help. I was in the right area but guess there must be some more panels to remove.
        • duanew
          • Mar 2012
          • 35
          A Little Late But
          you DO NOT have to Remove HDD in the Machine
          Just tell the creo to burn the Jobs in the Queue
          And if your worried about scan memory
          Scan a whole bunch of red sheets of paper intill the memory is at 100 percent
          then only a serious nut Hdd wizard will be able to retrieve left over data if any
