4110 Code 062-380
  • denden4h
    • Mar 2006
    • 31
    [Error Code] 4110 Code 062-380
    I really need some help on this one. I have a Xerox 4110 with a fault code 062-380. I have cleaned the optics and white strip. I have re-initialized the system more than once. If I turn the unit off, and unplug it, it will come ready, but if I restart it, the code comes back. The manual says to change the ccd and lens. I want to know if anyone has had this problem and if there is something I can do before ordering the expensive parts the manual says I need.
  • Flash
    • 378
    Re: 4110 Code 062-380
    You might have a bad CCD. Check the optics cooling fans also.
    • Exok
      • Jun 2011
      • 750
      Reseat CCD and IPS cabling. Retry. If problem returns, replace the CCD.
      I have had this once on a 4112. I replaced the CCD and that took care of the problem.
      • knightfall
        • Jul 2006
        • 633
        it is the ccd lens assembly also the copy bottom is not activated, just replace the lens assembly it should resolve the fault code.
        Get your facts first, and then you can distort them as much as you please.
        • denden4h
          • Mar 2006
          • 31
          Thanks guys, the lens/ccd kit worked.
          • vishop
            • Jan 2011
            • 220
            Could anyone share with me the part # for this CCD assy?
            Thank You
            • jozkie
              Originally posted by vishop
              Thank You
              604k21506 p/n
